Build(deps): Bump docile from 1.3.5 to 1.4.0 (PR #13050)
Bumps docile from 1.3.5 to 1.4.0.
Changelog
Sourced from docile's changelog.
v1.4.0 (May 12, 2021)
  • Special thanks to Matt Schreiber (@​tomeon):
    • Short-circuit to calling #instance_exec directly on the DSL object (prior to constructing a proxy object) when the DSL object and block context object are identical (Sorry it took over a year to review and merge this!)
  • Renamed default branch from master to main, see: https://github.com/github/renaming
  • Temporarily removed YARD doc configuration, to replace after migration to Github Actions
  • Removed support for all EOL Rubies < 2.6
  • Migrated CI from Travis to Github Actions
  • Special thanks (again!) to Taichi Ishitani (@​taichi-ishitani):
    • Use more reliable codecov github action (via simplecov-cobertura) rather than less reliable codecov gem
    • Enable bundle caching in github action setup-ruby
  • Added Rubocop, and configured it to run in CI
  • Added Dependabot, and configured it to run daily
  • Added SECURITY.md for vulnerability reporting policy
Commits
  • f87c158 Bump version to 1.4.0
  • 40ef404 Update HISTORY.md for 1.4.0
  • ef1db93 Update comment for modern Rubies
  • 671fd2f Update README.md - add release instructions
  • 9fafdfa Update HISTORY.md for Rubocop, Dependabot, and SECURITY.md
  • d3d1d55 Merge pull request #73 from ms-ati/dependabot/github_actions/actions/checkout...
  • 9999c40 Merge pull request #74 from ms-ati/dependabot/github_actions/codecov/codecov-...
  • e0a3e10 Bump codecov/codecov-action from 1 to 1.5.0
  • 95438df Bump actions/checkout from 2 to 2.3.4
  • fba9f01 Merge pull request #72 from ms-ati/add-dependabot
  • Additional commits viewable in compare view
GitHub
