Build(deps): Bump ecma-re-validator from 0.3.0 to 0.4.0 (PR #15557)
Bumps ecma-re-validator from 0.3.0 to 0.4.0.
Commits
GitHub
Used for API docs via json_schemer, changes all look totally safe.
