Build(deps): Bump elliptic from 6.5.2 to 6.5.3 in /app/assets/javascripts/discourse-common (PR #10612)
Bumps elliptic from 6.5.2 to 6.5.3.
Commits
You can disable automated security fix PRs for this repo from the Security Alerts page.
GitHub
