Build(deps): Bump excon from 0.72.0 to 0.73.0 (PR #9228)
Bumps excon from 0.72.0 to 0.73.0.
Changelog
Sourced from excon's changelog.
0.73.0 2020-03-17
add request/response data to proxy errors
Commits
  • d59f340 v0.73.0
  • 7956635 Merge pull request #715 from cds2-stripe/cds/augment-proxy-connection-error
  • 36744bd include both request and response in ProxyConnectionError
  • c39c6a2 embed response from proxy in ProxyConnectionError
  • See full diff in compare view
GitHub
This seems to break a lot of plugin tests.
@dependabot-bot rebase
