Build(deps): Bump excon from 0.73.0 to 0.74.0 (PR #10046)
Bumps excon from 0.73.0 to 0.74.0.
Changelog
Sourced from excon's changelog.
0.74.0 2020-06-12
add ipv6 support to no-proxy handling comment out add trust cert from bundle (due to expiry)
Commits
GitHub
@dependabot rebase
