Build(deps): Bump excon from 0.76.0 to 0.77.0 (PR #10941)
Bumps excon from 0.76.0 to 0.77.0.
Commits
  • c100561 v0.77.0
  • 4915550 update bundled certs
  • 6b20581 Merge pull request #723 from andrepiske/host-always-first-header
  • bc9fda1 Add comment stating why Host is being hoisted
  • 64b7565 Test that host header is the first by default
  • 75d5ce5 Make Host header be always the first in requests
  • See full diff in compare view
GitHub
Looks like excon is up-to-date now, so this is no longer needed.
