Build(deps): Bump excon from 0.76.0 to 0.78.0 (PR #10949)
Bumps excon from 0.76.0 to 0.78.0.
Changelog
Sourced from excon's changelog.
0.78.0 2020-10-16
Fix bash-specific gemspec expansion which caused files to be missing in zsh
0.77.0 2020-10-16
Ensure host is first request header, see: RFC 7230 Section 5.4 Update bundled certificates
Commits
  • 49cef40 v0.78.0
  • 8852c06 fix bash-specific expansion in gemspec, which was breaking in zsh
  • c100561 v0.77.0
  • 4915550 update bundled certs
  • 6b20581 Merge pull request #723 from andrepiske/host-always-first-header
  • bc9fda1 Add comment stating why Host is being hoisted
  • 64b7565 Test that host header is the first by default
  • 75d5ce5 Make Host header be always the first in requests
  • See full diff in compare view
GitHub
