Build(deps): Bump excon from 0.81.0 to 0.82.0 (PR #13192)
Bumps excon from 0.81.0 to 0.82.0.
Changelog
Sourced from excon's changelog.
0.82.0 2021-05-27
update actions/checkout update actions/stale update bundled certs
Commits
  • b43cdd7 v0.82.0
  • 6967612 update bundled certs
  • 27dcc89 Merge pull request #750 from excon/dependabot/github_actions/actions/stale-3....
  • 448b0c7 Bump actions/stale from 3.0.18 to 3.0.19
  • 71f999a Merge pull request #749 from excon/dependabot/github_actions/actions/checkout...
  • ca1b6c1 Merge pull request #748 from excon/dependabot/github_actions/actions/stale-3....
  • 1a11afb Bump actions/checkout from 2 to 2.3.4
  • c4e3918 Bump actions/stale from 3 to 3.0.18
  • See full diff in compare view
GitHub
