Build(deps): Bump excon from 0.82.0 to 0.83.0 (PR #13558)
Bumps excon from 0.82.0 to 0.83.0.
Changelog
Sourced from excon's changelog.
0.83.0 2021-06-28
add ssl_security_level option with pass through to ssl_context
Commits
GitHub
