Build(deps): Bump excon from 0.84.0 to 0.85.0 (PR #13772)
Bumps excon from 0.84.0 to 0.85.0.
Changelog
Sourced from excon's changelog.
0.85.0 2021-07-16
fix socket datum regression introduced in #742
Commits
  • b64de99 v0.85.0
  • 7aa10f8 Merge pull request #754 from jjiang-stripe/jjiang/fix-socket
  • 653e69d Overwrite socket data if already initialized
  • 089dc7f Merge pull request #753 from excon/dependabot/github_actions/actions/stale-4
  • 78035eb Bump actions/stale from 3.0.19 to 4
  • See full diff in compare view
GitHub
