Build(deps): Bump excon from 0.85.0 to 0.86.0 (PR #14495)
Bumps excon from 0.85.0 to 0.86.0.
Changelog
Sourced from excon's changelog.
0.86.0 2021-10-01
prevent test suite stall on test server failure fix logging behavior for query hashes improve debbuging by reading server response during EPIPE errors update bundled certs
Commits
  • f062ba5 v0.86.0
  • c76f4be update bundled certs
  • 5f384be Merge pull request #761 from stanhu/sh-epipe-show-server-response
  • dc10c8b [fix] Read server response during EPIPE
  • 973e581 Merge pull request #759 from carlfin/logging-instrumentor-queries-as-hash
  • bb90e2c [fix] untangle logfile names for tests
  • 61ee867 [fix] typo/syntax error on test code
  • bbeb35a [fix] logging behavior for query hashes
  • 4075233 Merge pull request #758 from voxik/report-test-server-issues
  • 256c224 Prevent test suite lockups on test server failure
  • See full diff in compare view
GitHub
