Build(deps): Bump excon from 0.87.0 to 0.88.0 (PR #14751)
Bumps excon from 0.87.0 to 0.88.0.
Changelog
Sourced from excon's changelog.
0.88.0 2021-10-27
update bundled certs
Commits
GitHub
