Build(deps): Bump execjs from 2.7.0 to 2.8.0 (PR #13016)
Bumps execjs from 2.7.0 to 2.8.0.
Commits
  • 2cac62d ExecJS 2.8.0
  • 829c22d Merge pull request #98 from casperisfine/github-actions
  • 2af3225 Remove travis config
  • 0c34623 Add jruby and truffle-ruby
  • a7a4096 Add NodeJS to the CI
  • c5fd11d Explicitly call process.exit in the node runner to prevent it from hanging
  • 1dce3d0 Update JavaScriptCore path
  • 8eadf60 Use macos latest
  • 75b69a4 Upgrade bundler and rubygems on CI
  • 70e8498 Fix a test failure and minitest warnings
  • Additional commits viewable in compare view
GitHub
@dependabot rebase
