Build(deps): Bump exifr from 1.3.6 to 1.3.7 (PR #10650)
Bumps exifr from 1.3.6 to 1.3.7.
Changelog
Sourced from exifr's changelog.
EXIF Reader 1.3.7
  • bug fix; "Does not raise error when it has invalid thumbails data"; thanks Fabio Perrella
  • enhancement; "Add metadata for RubyGems"; thanks Stanisław Pitucha
EXIF Reader 1.3.6
  • bug fix; "Support GPSHPositioningError"; thanks Ken-ichi
EXIF Reader 1.3.5
  • enhancement; "Support milliseconds at DateTime"; thanks Naoki Iwasawa
EXIF Reader 1.3.4
  • bug fix; "Modernize #methods method signatures for delegate.rb"; thanks Julik Tarkhanov
EXIF Reader 1.3.3
  • bug fix; "Using first gps altitude value in case 'gps_altitude' is an Array"; thanks Antonio Marques
EXIF Reader 1.3.2
  • enhancement; "Add EXIF 2.3 lens information tags"; thanks Clay Gregory
EXIF Reader 1.3.1
  • fix executable bin/exifr
EXIF Reader 1.3.0
  • workaround warnings when using the ruby "-w" option
  • NOTE: requiring only 'exifr' will nolonger provide EXIFR::JPEG or EXIFR::TIFF, require 'exifr/jpeg' or 'exifr/tiff' instead
EXIF Reader 1.2.6
  • bug fix; "[GH#48] handle empty file as malformed jpeg"; thanks Hoàng Xuân Phú
EXIF Reader 1.2.5
  • bug fix; "[GH#46] Having stringified methods is not a good idea"; thanks Filipe Costa
  • bug fix; "Fix typo in subsec_time_original key"; thanks Filipe Costa
EXIF Reader 1.2.4
  • bug fix; "[GH#43] Fix respond_to? signature"; thanks Pete Johns
EXIF Reader 1.2.3.1
  • bug fix; "[GH#41] gopro_hd2.exif is not included in the gem"; thanks Peter Wilmott
EXIF Reader 1.2.3
  • bug fix; "[GH#40] Handle NUL-terminated ASCII strings"; thanks Malte Rohde
EXIF Reader 1.2.2
  • bug fix; "use Reader delegator instead of adding method to File instance"; thanks Ivan Kuchin
EXIF Reader 1.2.1
  • bug fix: Value of infinity yields division by zero error
EXIF Reader 1.2.0
  • enhancement; "log warnings when EXIF data is malformed"
Commits
GitHub
