Build(deps): Bump faker from 2.17.0 to 2.18.0 (PR #13073)
Bumps faker from 2.17.0 to 2.18.0.
Release notes
Sourced from faker's releases.
v2.18.0
This version:
  • fixes bugs and chores
  • update documentation
  • adds new generators for IDNumber, Crypto.sha512, and others.
  • updates locales in different languages
  • updates dependencies
Changelog
Sourced from faker's changelog.
v2.18.0 (2021-05-15)
Bug/Fixes
Chores
Documentation
Feature Request
Update locales
Update local dependencies
  • Update rubocop requirement from = 1.13.0 to = 1.14.0 (#2314)
  • Upgrade to GitHub-native Dependabot (#2310)
  • Update rubocop requirement from = 1.12.1 to = 1.13.0 (#2305)
  • Update test-unit requirement from = 3.4.0 to = 3.4.1 (#2303)
  • Update pry requirement from = 0.14.0 to = 0.14.1 (#2298)
  • Update rubocop requirement from = 1.12.0 to = 1.12.1 (#2294)
  • Update rubocop requirement from = 1.11.0 to = 1.12.0 (#2288)
Commits
  • be59d0b Bump version to 2.18.0 (#2323)
  • e4ef1ab Remove Canadian 226 area code from array of US area codes (resolves #2321) (#...
  • 1c1b561 Merge pull request #2314 from faker-ruby/dependabot/bundler/rubocop-1.14.0
  • 210778f Update rubocop requirement from = 1.13.0 to = 1.14.0
  • 9397e3f Merge pull request #2317 from yujideveloper/fix/ci-for-es-ar
  • 7b81bdf Fix redundant escape inside regexp literal
  • 98bab62 Fix ci for es-AR
  • e2f77bf Merge pull request #2316 from yujideveloper/fix/typo-test-method
  • dcd21cd Fix typo in test method
  • e110fa4 Split JA translation file into one file per class (#2315)
  • Additional commits viewable in compare view
GitHub
Safe to merge but can wait post-release.
