Build(deps): Bump faraday from 1.0.1 to 1.1.0 (PR #10950)
Bumps faraday from 1.0.1 to 1.1.0.
Release notes
Sourced from faraday's releases.
v1.1.0
Features
Fixes
  • Avoid last arg as keyword param warning when building user middleware on Ruby 2.7 (#1153 @dgholz)
  • Limits net-http-persistent version to < 4.0 (#1156 @iMacTia)
  • Update typhoeus to new stable version (1.4) (#1159 @AlexWayfer)
  • Properly fix test failure with Rack 2.1+. (#1171 @voxik)
Documentation
  • Improves documentation on how to contribute to the site by using Docker. (#1175 @iMacTia)
  • Remove retry_change_requests from documentation (#1185 @stim371)
Misc
Commits
  • 571dc11 Version bump to 1.1.0
  • 0461c4b Upgrade CI to ruby/setup-ruby (#1187)
  • 85b46be Remove retry_change_requests from documentation (#1185)
  • a5b7a6b Drop git ls-files in gemspec (#1183)
  • 8ee406d Include request info in exceptions raised by RaiseError Middleware (#1181)
  • 868fe9b Fix linting bumping Rubocop to 0.90.0 (#1182)
  • 9af091f Improves documentation on how to contribute to the site by using Docker. (#1175)
  • 6521a16 Properly fix test failure with Rack 2.1+.
  • 5acab36 Introduces flat_encode option for multipart adapter. (#1163)
  • e02a8c1 Makes parameters sorting configurable (#1162)
  • Additional commits viewable in compare view
GitHub
