Build(deps): Bump faraday from 1.3.0 to 1.4.1 (PR #12748)
Bumps faraday from 1.3.0 to 1.4.1.
Release notes
Sourced from faraday's releases.
v1.4.1
Fixes
v1.4.0
Highlights
With this release, we continue the work of gradually moving out adapters into their own gems 🎉 Thanks to @​MikeRogers0 for helping the Faraday team in progressing with this quest 👏
And thanks to @​olleolleolle efforts, Faraday is becoming more inclusive than ever 🤗 Faraday's master branch has been renamed into main, we have an official policy on inclusive language and even a rubocop plugin to check for non-inclusive words ❤️! Checkout the "Misc" section below for more details 🙌 !
Fixes
Documentation
Misc
v1.3.1
Fixes
Documentation
Misc
Changelog
Sourced from faraday's changelog.
Faraday Changelog
Commits
GitHub
