Build(deps): Bump faraday from 1.4.1 to 1.4.2 (PR #13120)
Bumps faraday from 1.4.1 to 1.4.2.
Release notes
Sourced from faraday's releases.
v1.4.2
Fixes:
Documentation:
Misc:
Commits
GitHub
