Build(deps): Bump faraday from 1.5.0 to 1.5.1 (PR #13697)
Bumps faraday from 1.5.0 to 1.5.1.
Release notes
Sourced from faraday's releases.
v1.5.1
Fixes
  • Fix JRuby incompatibility after moving out EM adapters (#1294, @​ahorek)
Documentation
Commits
GitHub
