Build(deps): Bump faraday from 1.7.0 to 1.7.1 (PR #14191)
Bumps faraday from 1.7.0 to 1.7.1.
Release notes
Sourced from faraday's releases.
v1.7.1
Fixes
Deprecations
Changelog
Sourced from faraday's changelog.
Faraday Changelog
Commits
GitHub
