Build(deps): Bump faraday from 1.7.1 to 1.7.2 (PR #14333)
Bumps faraday from 1.7.1 to 1.7.2.
Release notes
Sourced from faraday's releases.
v1.7.2
Fixes
Commits
GitHub
