Build(deps): Bump faraday-net_http from 1.0.0 to 1.0.1 (PR #11695)
Bumps faraday-net_http from 1.0.0 to 1.0.1.
Release notes
Sourced from faraday-net_http's releases.
v1.0.1
Fixes:
Commits
  • d1ca243 Version bump to 1.0.1
  • a23fbc8 Moves require 'faraday' to spec_helper to avoid circular dependency.
  • See full diff in compare view
GitHub
