Build(deps): Bump fastimage from 2.2.4 to 2.2.5 (PR #14002)
Bumps fastimage from 2.2.4 to 2.2.5.
Changelog
Sourced from fastimage's changelog.
Version 2.2.5
10-August-2021
  • FIX: handle HEIC/HEIF rotation angle
Version 2.2.4
02-June-2021
  • FEATURE: Added support for HEIC format
  • FIX: Support SVG files that start with a BOM character
Commits
  • a1131d1 Bump version and introduce version file
  • f655910 Merge pull request #131 from stefanoverna/fix-heic-rotation-angle
  • 6025bd8 Use irot box to get HEIC/HEIF rotation angle
  • See full diff in compare view
GitHub
