Build(deps): Bump ffi from 1.12.2 to 1.13.0 (PR #9954)
Bumps ffi from 1.12.2 to 1.13.0.
Changelog
Sourced from ffi's changelog.
1.13.0 / 2020-06-01
Added:
  • Add TruffleRuby support. Almost all specs are running on TruffleRuby and succeed. #768
  • Add ruby source files to the java gem. This allows to ship the Ruby library code per platform java gem and add it as a default gem to JRuby. #763
  • Add FFI::Platform::LONG_DOUBLE_SIZE
  • Add bounds checks for writing to an inline char[] . #756
  • Add long double as callback return value. #771
  • Update type definitions and add types from stdint.h and stddef.h on i386-windows, x86_64-windows, x86_64-darwin, x86_64-linux, arm-linux, powerpc-linux. #749
  • Add new type definitions for powerpc-openbsd and sparcv9-openbsd. #775, #778
Changed:
  • Raise required ruby version to >= 2.3.
  • Lots of cleanups and improvements in library, specs and benchmarks.
  • Fix a lot of compiler warnings at the C-extension
  • Fix several install issues on MacOS:
    • Look for libffi in SDK paths, since recent versions of macOS removed it from /usr/include . #757
    • Fix error ld: library not found for -lgcc_s.10.4
    • Don't built for i386 architecture as it is deprecated
  • Several fixes for MSVC build on Windows. #779
  • Use ucrtbase.dll as default C library on Windows instead of old msvcrt.dll. #779
  • Update builtin libffi to fix a Powerpc issue with parameters of type long
  • Allow unmodified sourcing of (the ruby code of) this gem in JRuby and TruffleRuby as a default gem. #747
  • Improve check to detect if a module has a #find_type method suitable for FFI. This fixes compatibility with stdlib mkmf . #776
Removed:
  • Reject callback with :string return type at definition, because it didn't work so far and is not save to use. #751, #782
Commits
GitHub
