Build(deps): Bump ffi from 1.13.0 to 1.13.1 (PR #10006)
Bumps ffi from 1.13.0 to 1.13.1.
Changelog
Sourced from ffi's changelog.
1.13.1 / 2020-06-09
Changed:
  • Revert use of ucrtbase.dll as default C library on Windows-MINGW. ucrtbase.dll is still used on MSWIN target. #790
  • Test for ffi_prep_closure_loc() to make sure we can use this function. This fixes incorrect use of system libffi on MacOS Mojave (10.14). #787
  • Update types.conf on x86_64-dragonflybsd
Commits
  • 4b053c8 Update CHANGELOG for 1.13.1
  • a03ffb6 Bump VERSION to 1.13.1
  • 18370af Merge pull request #790 from larskanis/msvcrt-on-mingw#
  • f2d35a9 Add a spec regarding issue #788
  • 90f4fca Revert usage of libc's time() on MINGW
  • cc32fd0 Remove unused strcat() mapping in specs
  • f259139 Revert to msvcrt.dll as LIBC on MINGW
  • 81dad3c Merge pull request #787 from larskanis/ffi_prep_closure_loc
  • 2c3979e Merge pull request #789 from ahorek/dragon
  • c9b01d7 Update types.conf on x86_64-dragonflybsd
  • Additional commits viewable in compare view
GitHub
