Build(deps): Bump ffi from 1.15.0 to 1.15.1 (PR #13121)
Bumps ffi from 1.15.0 to 1.15.1.
Changelog
Sourced from ffi's changelog.
1.15.1 / 2021-05-22
Fixed:
  • Append -pthread to linker options. #893
  • Use arm or aarch64 to identify Apple ARM CPU arch. #899
  • Allow overriding gcc with the CC env var in const_generator.rb and struct_generator.rb. #897
Commits
  • 513aef4 Bump VERSION to 1.15.1
  • a0a457b Update CHANGELOG for ffi-1.15.1
  • 54db5ef Append -pthread to linker options
  • 4ad6fd5 Merge pull request #899 from andrewferk/apple-m1-arm-aarch64
  • 3056009 Use arm or aarch64 to identify Apple ARM CPU arch
  • 4430b6d Merge pull request #897 from leshik/fix-cc
  • 928e3f9 Allow overriding gcc with the CC env var in const_generator.rb and `str...
  • 2cc0e53 Relax bundler version for JRuby on Github Actions
  • 9d7eeb7 Merge branch 'master' of github.com:ffi/ffi
  • 85f7db9 Revert "Enable loading FFI gem on rubinius"
  • Additional commits viewable in compare view
GitHub
