Build(deps): Bump ffi from 1.15.1 to 1.15.3 (PR #13408)
Bumps ffi from 1.15.1 to 1.15.3.
Changelog
Sourced from ffi's changelog.
1.15.3 / 2021-06-16
Fixed:
  • Fix temporary packaging issue with libffi. #904
1.15.2 / 2021-06-16
Added:
  • Add support for Windows MINGW-UCRT build. #903
  • Add /opt/homebrew/lib/ to fallback search paths to improve homebrew support. #880 #882
Changed:
  • Regenerate types.conf for FreeBSD12 aarch64. #902
Commits
  • 931efbe Bump VERSION to 1.15.3
  • 6fc849f Add CHANGELOG entry for ffi-1.15.2
  • 36cee2c Bump VERSION to 1.15.2
  • 4924308 Fix Windows libc detection for MSYS2-ucrt build (#903)
  • 036a1a3 Merge pull request #902 from MikaelUrankar/master
  • 264c3f7 Regen types.conf for FreeBSD12 aarch64
  • 393a833 Switch time_t and suseconds_t types to long on FreeBSD aarch64
  • 82e2092 Merge pull request #882 from OleMchls/patch-1
  • See full diff in compare view
GitHub
