Build(deps): Bump globalid from 0.4.2 to 0.5.1 (PR #13866)
Bumps globalid from 0.4.2 to 0.5.1.
Release notes
Sourced from globalid's releases.
v0.5.1
  • New: Allow expiration to be turned off globally rails/globalid#128
  • Fixed: Support for ruby-head rails/globalid#132
  • Maintainance: Drop support for EOL'ed Rubies (< 2.6.0) and Rails 4.2
Commits
  • 20f6a4a Bump to 0.5.1 for Active Support Gemfile.lock update
  • 1366dc0 Looks like the matrix option has been renamed to jobs
  • 444b8a0 Try incluces over exclude
  • c00b25c rbx-2 isn't supported on CI anymore, cut it
  • e5f557d Test with Ruby 3 and exclude matrix versions that don't coexist
  • ac8b7f0 Railties is also a test dependency, like 5.0+ gemfiles
  • 403e25e Test integration with Rails 6.0+
  • 4ed45f5 Ditch long since EOL'ed Rails 4.2 support
  • 5b255ff Cut out EOL Ruby versions (< 2.6.0)
  • 3d8e64d Fix CI script indentation to match before_install/before_script etc
  • Additional commits viewable in compare view
GitHub
