Build(deps): Bump globalid from 0.5.2 to 0.6.0 (PR #15098)
Bumps globalid from 0.5.2 to 0.6.0.
Release notes
Sourced from globalid's releases.
0.6.0
  • Add ActiveRecord::FixtureSet.signed_global_id helper to generate signed ids inside fixtures.
Commits
  • beab3e4 Prepare to 0.6.0
  • 29e12cb Upgrade all development gems
  • c894a43 Add devcontainer to allow contributors to have a working environment
  • b3ec8b9 Move ActiveRecord::FixtureSet.signed_global_id to this gem
  • e9d6ed9 Merge pull request #137 from rails/dependabot/bundler/nokogiri-1.12.5
  • a565d31 Bump nokogiri from 1.11.7 to 1.12.5
  • 9b1a4d2 Why u no love me?
  • See full diff in compare view
GitHub
