Build(deps): Bump handlebars from 4.7.6 to 4.7.7 (PR #114)
Bumps handlebars from 4.7.6 to 4.7.7.
Changelog
Sourced from handlebars's changelog.
v4.7.7 - February 15th, 2021
  • fix weird error in integration tests - eb860c0
  • fix: check prototype property access in strict-mode (#1736) - b6d3de7
  • fix: escape property names in compat mode (#1736) - f058970
  • refactor: In spec tests, use expectTemplate over equals and shouldThrow (#1683) - 77825f8
  • chore: start testing on Node.js 12 and 13 - 3789a30
(POSSIBLY) BREAKING CHANGES:
  • the changes from version 4.6.0 now also apply in when using the compile-option "strict: true". Access to prototype properties is forbidden completely by default, specific properties or methods can be allowed via runtime-options. See #1633 for details. If you are using Handlebars as documented, you should not be accessing prototype properties from your template anyway, so the changes should not be a problem for you. Only the use of undocumented features can break your build.
That is why we only bump the patch version despite mentioning breaking changes.
Commits
Commits
  • a9a8e40 v4.7.7
  • e66aed5 Update release notes
  • 7d4d170 disable IE in Saucelabs tests
  • eb860c0 fix weird error in integration tests
  • b6d3de7 fix: check prototype property access in strict-mode (#1736)
  • f058970 fix: escape property names in compat mode (#1736)
  • 77825f8 refator: In spec tests, use expectTemplate over equals and shouldThrow (#1683)
  • 3789a30 chore: start testing on Node.js 12 and 13
  • See full diff in compare view
You can disable automated security fix PRs for this repo from the Security Alerts page.
GitHub
