Build(deps): Bump handlebars from 4.7.6 to 4.7.7 (PR #13023)
Bumps handlebars from 4.7.6 to 4.7.7.
Changelog
Sourced from handlebars's changelog.
v4.7.7 - February 15th, 2021
  • fix weird error in integration tests - eb860c0
  • fix: check prototype property access in strict-mode (#1736) - b6d3de7
  • fix: escape property names in compat mode (#1736) - f058970
  • refactor: In spec tests, use expectTemplate over equals and shouldThrow (#1683) - 77825f8
  • chore: start testing on Node.js 12 and 13 - 3789a30
(POSSIBLY) BREAKING CHANGES:
  • the changes from version 4.6.0 now also apply in when using the compile-option "strict: true". Access to prototype properties is forbidden completely by default, specific properties or methods can be allowed via runtime-options. See #1633 for details. If you are using Handlebars as documented, you should not be accessing prototype properties from your template anyway, so the changes should not be a problem for you. Only the use of undocumented features can break your build.
That is why we only bump the patch version despite mentioning breaking changes.
Commits
Commits
  • a9a8e40 v4.7.7
  • e66aed5 Update release notes
  • 7d4d170 disable IE in Saucelabs tests
  • eb860c0 fix weird error in integration tests
  • b6d3de7 fix: check prototype property access in strict-mode (#1736)
  • f058970 fix: escape property names in compat mode (#1736)
  • 77825f8 refator: In spec tests, use expectTemplate over equals and shouldThrow (#1683)
  • 3789a30 chore: start testing on Node.js 12 and 13
  • See full diff in compare view
  • @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) You can disable automated security fix PRs for this repo from the Security Alerts page.
GitHub
OK, I won’t notify you again about this release, but will get in touch when a new version is available.
If you change your mind, just re-open this PR and I’ll resolve any conflicts on it.
