Build(deps): Bump hashie from 4.1.0 to 5.0.0 (PR #14849)
Bumps hashie from 4.1.0 to 5.0.0.
Changelog
Sourced from hashie's changelog.
5.0.0 - 2021-11-08
Added
Changed
Removed
Fixed
  • #516: Fixed NoMethodError raised when including Hashie::Extensions::Mash::SymbolizeKeys and Hashie::Extensions::SymbolizeKeys in mashes/hashes with non string or symbol keys - @​carolineartz.
  • #531: Fixed slice doesn't work using symbols using hash with IndifferentAccess extension - @​gnomex.
  • #533: Fixed NoMethodError: undefined method 'to_json' at hashie/dash_spec - @​gnomex.
  • #535: Restored the exporting of all properties as part of Dash#to_h and Dash#to_hash - @​michaelherold.
  • #537: Fixed inconsistencies with handling defaults in Dash with and without IgnoreUnclared mixed in - @​michaelherold.
  • #547: Fixed issue where a source hash key can be used in translating multiple properties - @​danwa5.
Commits
GitHub
