Build(deps): Bump http-proxy from 1.18.0 to 1.18.1 in /app/assets/javascripts/pretty-text (PR #10614)
Bumps http-proxy from 1.18.0 to 1.18.1.
Changelog
Sourced from http-proxy's changelog.
v1.18.1 - 2020-05-17
Merged
Commits
You can disable automated security fix PRs for this repo from the Security Alerts page.
GitHub
