Build(deps): Bump https-proxy-agent from 2.2.1 to 2.2.4 (PR #9453)
Bumps https-proxy-agent from 2.2.1 to 2.2.4.
Release notes
Sourced from https-proxy-agent's releases.
2.2.4
Patches
  • Add .editorconfig file: a0d4a20458498fc31e5721471bd2b655e992d44b
  • Add .eslintrc.js file: eecea74a1db1c943eaa4f667a561fd47c33da897
  • Use a net.Socket instead of a plain EventEmitter for replaying proxy errors: #83
  • Remove unused stream module: 9fdcd47bd813e9979ee57920c69e2ee2e0683cd4
Credits
Huge thanks to @lpinca for helping!
2.2.3
Patches
  • Update README with actual secureProxy behavior: #65
  • Update proxy to v1.0.0: d0e3c18079119057b05582cb72d4fda21dfc2546
  • Remove unreachable code: 46aad0988b471f042856436cf3192b0e09e36fe6
  • Test on Node.js 10 and 12: 3535951e482ea52af4888938f59649ed92e81b2b
  • Fix compatibility with Node.js >= 10.0.0: #73
  • Use an EventEmitter to replay failed proxy connect HTTP requests: #77
Credits
Huge thanks to @stoically, @lpinca, and @zkochan for helping!
2.2.2
Patches
  • Remove package-lock.json: c881009b9873707f5c4a0e9c277dde588e1139c7
  • Ignore test directory, History.md and .travis.yml when creating npm package. Fixes #42: #45
  • Update agent-base to v4.2: #50
  • Add TypeScript type definitions: #66
  • Feat(typescript): Allow input to be options or string: #68
  • Update agent-base to v4.3: #69
Credits
Huge thanks to @marco-c, @tareqhs, @ianhowe76, and @BYK for helping!
Commits
You can disable automated security fix PRs for this repo from the Security Alerts page.
GitHub
