Build(deps): Bump i18n from 1.8.10 to 1.8.11 (PR #14811)
Bumps i18n from 1.8.10 to 1.8.11.
Release notes
Sourced from i18n's releases.
v1.8.11
What's Changed
New Contributors
Full Changelog: https://github.com/ruby-i18n/i18n/compare/v1.8.10...v1.8.11
Commits
  • cb4a4be Bump to 1.8.11
  • 916f9f4 Merge pull request #569 from koic/fix_build_error_when_using_psych_4_0
  • 3d0f144 Merge pull request #572 from codealchemy/simple_backend/json-test-fix
  • 9dbbcfc Fix typo in Simple backend JSON test
  • 1edbf5c Fix a build error when using Psych 4.0
  • 95612de Merge pull request #566 from codealchemy/simple_backend/consolidate-available...
  • 346f1cd Update available locale check in Simple backend
  • f19ee0d Merge pull request #565 from rkh/patch-1
  • 535459a Fix typo in documentation
  • See full diff in compare view
GitHub
