Build(deps): Bump i18n from 1.8.3 to 1.8.4 (PR #10266)
Bumps i18n from 1.8.3 to 1.8.4.
Release notes
Sourced from i18n's releases.
v1.8.4
  • Fixed issue where fallbacks were not working when I18n.fallbacks was an array - #534
  • Fixed conditional around deprecating constant of INTERPOLATION_PATTERN - #531
Commits
  • 71a51b3 Bump to 1.8.4
  • 360b8b7 Merge pull request #535 from ruby-i18n/fallbacks
  • 1cb0987 Always instantiate I18n::Locale::Fallbacks objects when using I18n.fallbacks=
  • dfd1e29 Ensure documentation for fallbacks reflects reality
  • c2d85c0 Merge pull request #532 from ruby-i18n/deprecate-constant
  • 76c677a Can we call deprecate_constant without checking respond_to?
  • 4e1a134 Merge pull request #531 from Fatsoma/deprecate_constant_interpolation_pattern
  • 87b0718 Fix deprecate_constant INTERPOLATION_PATTERN
  • See full diff in compare view
GitHub
This seems to be a breaking change. @gschlager maybe you can investigate this one?
Superseded by #10300.
