Build(deps): Bump i18n from 1.8.9 to 1.8.10 (PR #12576)
Bumps i18n from 1.8.9 to 1.8.10.
Release notes
Sourced from i18n's releases.
1.8.10
  • Fix string locale will trigger on_fallback hook - #562
Commits
GitHub
