Build(deps): Bump image_optim from 0.30.0 to 0.31.0 (PR #14494)
Bumps image_optim from 0.30.0 to 0.31.0.
Changelog
Sourced from image_optim's changelog.
v0.31.0 (2021-10-03)
Commits
GitHub
@oblakeerickson Nice :slight_smile:
