Bumps ini from 1.3.5 to 1.3.8.
Commits
a2c5da8
1.3.8 -
af5c6bb
Do not use Object.create(null) -
8b648a1
don't test where our devdeps don't even work -
c74c8af
1.3.7 -
024b8b5
update deps, add linting -
032fbaf
Use Object.create(null) to avoid default object property hazards -
2da9039
1.3.6 -
cfea636
better git push script, before publish instead of after -
56d2805
do not allow invalid hazardous string as section name - See full diff in compare view
Maintainer changes
This version was pushed to npm by isaacs, a new releaser for ini since your current version.
Dependabot will resolve any conflicts with this PR as long as you don’t alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase
@dependabot rebase
will rebase this PR -
@dependabot recreate
will recreate this PR, overwriting any edits that have been made to it -
@dependabot merge
will merge this PR after your CI passes on it -
@dependabot squash and merge
will squash and merge this PR after your CI passes on it -
@dependabot cancel merge
will cancel a previously requested merge and block automerging -
@dependabot reopen
will reopen this PR if it is closed -
@dependabot close
will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually -
@dependabot ignore this major version
will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself) -
@dependabot ignore this minor version
will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself) -
@dependabot ignore this dependency
will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) -
@dependabot use these labels
will set the current labels as the default for future PRs for this repo and language -
@dependabot use these reviewers
will set the current reviewers as the default for future PRs for this repo and language -
@dependabot use these assignees
will set the current assignees as the default for future PRs for this repo and language -
@dependabot use this milestone
will set the current milestone as the default for future PRs for this repo and language
You can disable automated security fix PRs for this repo from the Security Alerts page.
