Build(deps): Bump ini from 1.3.5 to 1.3.8 (PR #13029)
Bumps ini from 1.3.5 to 1.3.8.
Commits
  • a2c5da8 1.3.8
  • af5c6bb Do not use Object.create(null)
  • 8b648a1 don't test where our devdeps don't even work
  • c74c8af 1.3.7
  • 024b8b5 update deps, add linting
  • 032fbaf Use Object.create(null) to avoid default object property hazards
  • 2da9039 1.3.6
  • cfea636 better git push script, before publish instead of after
  • 56d2805 do not allow invalid hazardous string as section name
  • See full diff in compare view
Maintainer changes
This version was pushed to npm by isaacs, a new releaser for ini since your current version.
  • @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) You can disable automated security fix PRs for this repo from the Security Alerts page.
GitHub
