Build(deps): Bump ipaddr from 1.2.2 to 1.2.3 (PR #14711)
Bumps ipaddr from 1.2.2 to 1.2.3.
Changelog
Sourced from ipaddr's changelog.
1.2.3
Commits
  • 37007e7 Bump version to 1.2.3
  • d4cb425 Add entries to CHANGELOG.md
  • 24e032e Merge pull request #32 from ruby/ci-use-bundler-cache
  • 18e991a CI: Use bundler-cache: true
  • 5a25ded Merge pull request #31 from jeremyevans/fix-drb-failures
  • 2059658 Do not require ruby2_keywords to run the tests
  • 5fb8e81 Test on JRuby 9.3
  • a326e91 Copy test/lib from drb
  • da22ef8 Fix include? and ipv4_mapped to allow drb tests to pass
  • 94c3391 Assert obsolete method warnings in IPAddr
  • Additional commits viewable in compare view
GitHub
