Build(deps): Bump jquery-rails from 4.3.5 to 4.4.0 (PR #9709)
Bumps jquery-rails from 4.3.5 to 4.4.0.
Changelog
Sourced from jquery-rails's changelog.
4.4.0
Commits
GitHub
