Build(deps): Bump json from 2.3.0 to 2.3.1 (PR #10147)
Bumps json from 2.3.0 to 2.3.1.
Changelog
Sourced from json's changelog.
Changes
Commits
  • 0951d77 Bump version to 2.3.1
  • ddc29e2 Merge pull request #429 from flori/remove-generate-task-for-gemspec
  • cee8020 Removed gemspec task from default task on Rakefile
  • 9fd6371 Use VERSION file instead of hard-coded value
  • dc90bcf Removed explicitly date field in gemspec, it will assign by rubygems.org
  • 4c11a40 Removed task for json_pure.gemspec
  • e794ec9 Merge pull request #426 from marcandre/indent
  • 7cc9301 Merge pull request #428 from marcandre/change_fix
  • 9e2a1fb Make changes more precise #424
  • f8fa987 Merge pull request #424 from marcandre/update_changes
  • Additional commits viewable in compare view
GitHub
