Build(deps): Bump json from 2.6.0 to 2.6.1 (PR #14704)
Bumps json from 2.6.0 to 2.6.1.
Changelog
Sourced from json's changelog.
2021-10-24 (2.6.1)
  • Restore version.rb with 2.6.1
Commits
  • 2db5894 Bump version to v2.6.1
  • 009619e Merge pull request #485 from RubyElders/bump
  • da94d9f Bump JSON::VERSION to 2.6.0.
  • 4423186 Merge pull request #480 from Shopify/restore-and-update-changes
  • 1022848 Write changelog for 2.6.0
  • e34e222 Revert "Delete CHANGES.md because there is no maintanance resource"
  • 739e064 Delete CHANGES.md because there is no maintanance resource
  • See full diff in compare view
GitHub
