Build(deps): Bump jwt from 2.2.1 to 2.2.2 (PR #10463)
Bumps jwt from 2.2.1 to 2.2.2.
Changelog
Sourced from jwt's changelog.
v2.2.2 (2020-08-18)
Full Changelog
Implemented enhancements:
  • JWK does not decode. #332
  • Inconsistent use of symbol and string keys in args (exp and alrogithm). #331
  • Pin simplecov to < 0.18 #356 (anakinj)
  • verifies algorithm before evaluating keyfinder #346 (jb08)
  • Update Rails 6 appraisal to use actual release version #336 (smudge)
  • Update Travis #326 (berkos)
  • Improvement/encode hmac without key #312 (JotaSe)
Fixed bugs:
  • v2.2.1 warning: already initialized constant JWT Error #335
Commits
  • d79d045 Update CHANGELOG
  • 88c0ad6 Update version to 2.2.2
  • 2492d58 Fix algorithm picking from options
  • d8dc68a Add tests using string keys for algorithm
  • 0f7dd57 Raise error when verification key is empty
  • f26eea6 Merge pull request #357 from excpt/issue/335
  • 57258e4 Fix 'already initialized constant JWT Error'
  • 95d8d9f encode hmac without key
  • b9b1b03 Update travis config to use 6.0 instead of rc1
  • e19fee8 Add Rails 6 appraisal
  • Additional commits viewable in compare view
GitHub
@dependabot rebase
