Build(deps): Bump jwt from 2.2.2 to 2.2.3 (PR #12775)
Bumps jwt from 2.2.2 to 2.2.3.
Changelog
Sourced from jwt's changelog.
2.2.3 (2021-04-19)
Full Changelog
Implemented enhancements:
  • Verify algorithm before evaluating keyfinder #343
  • Why jwt depends on json < 2.0 ? #179
  • Support for JWK in-lieu of rsa_public #158
  • Fix rspec raise_error warning #413 (excpt)
  • Add support for JWKs with HMAC key type. #372 (phlegx)
  • Improve 'none' algorithm handling #365 (danleyden)
  • Handle parsed JSON JWKS input with string keys #348 (martinemde)
  • Allow Numeric values during encoding #327 (fanfilmu)
Closed issues:
  • "Signature verification raised", yet jwt.io says "Signature Verified" #401
  • truffleruby-head build is failing #396
  • JWT::JWK::EC needs require 'forwardable' #392
  • How to use a 'signing key' as used by next-auth #389
  • undefined method `verify' for nil:NilClass when validate a JWT with JWK #383
  • Make specifying "algorithm" optional on decode #380
  • ADFS created access tokens can't be validated due to missing 'kid' header #370
  • new version? #355
  • JWT gitlab OmniAuth provider setup support #354
  • Release with support for RSA.import for ruby < 2.4 hasn't been released #347
  • cannot load such file -- jwt #339
Merged pull requests:
... (truncated)
Commits
GitHub
