Build(deps): Bump lodash from 4.17.15 to 4.17.20 in /app/assets/javascripts/discourse-common (PR #10616)
Bumps lodash from 4.17.15 to 4.17.20.
Commits
Maintainer changes
This version was pushed to npm by bnjmnt4n, a new releaser for lodash since your current version.
You can disable automated security fix PRs for this repo from the Security Alerts page.
GitHub
I strongly suspect the failure is unrelated.
