Build(deps): Bump lodash from 4.17.19 to 4.17.21 in /support/text-unicode-webpack (PR #16)
Bumps lodash from 4.17.19 to 4.17.21.
Commits
  • f299b52 Bump to v4.17.21
  • c4847eb Improve performance of toNumber, trim and trimEnd on large input strings
  • 3469357 Prevent command injection through _.template's variable option
  • ded9bc6 Bump to v4.17.20.
  • 63150ef Documentation fixes.
  • 00f0f62 test.js: Remove trailing comma.
  • 846e434 Temporarily use a custom fork of lodash-cli.
  • 5d046f3 Re-enable Travis tests on 4.17 branch.
  • aa816b3 Remove /npm-package.
  • See full diff in compare view
Maintainer changes
This version was pushed to npm by bnjmnt4n, a new releaser for lodash since your current version.
You can disable automated security fix PRs for this repo from the Security Alerts page.
GitHub
