Build(deps): Bump lodash from 4.17.20 to 4.17.21 (PR #115)
Bumps lodash from 4.17.20 to 4.17.21.
Commits
  • f299b52 Bump to v4.17.21
  • c4847eb Improve performance of toNumber, trim and trimEnd on large input strings
  • 3469357 Prevent command injection through _.template's variable option
  • See full diff in compare view
You can disable automated security fix PRs for this repo from the Security Alerts page.
GitHub
