Build(deps): Bump logster from 2.7.1 to 2.8.0 (PR #9310)
Bumps logster from 2.7.1 to 2.8.0.
Changelog
Sourced from logster's changelog.
CHANGELOG
  • 2020-03-30: 2.8.0
    • FEATURE: Upgrade icons to Font Awesome 5
  • 2020-03-03: 2.7.1
    • FIX: Stop env mutation to allow all chained loggers to have the same env (#110)
  • 2020-02-26: 2.7.0
    • FEATURE: Make log message max length configurable and bump the default to 2000 (#109)
  • 2020-02-17: 2.6.3
    • FIX: Respect redis namespace when fetching env using LUA
  • 2020-02-09: 2.6.2
    • FIX: Regression with rendering single env when env_expandable_keys config is present
    • DEV: Fix Ember deprecations in tests
    • DEV: Add more tests to env rendering
    • FIX: Backtrace frames from gems should be linkified even when they don't start with gems_dir
    • DEV: Allow Ember server to inherit preload data from Sinatra server
    • FIX: Fetch env when navigating through grouped messages
  • 2020-02-07: 2.6.1
    • FIX: Fetch env when row is selected to allow copy to work on Firefox
  • 2020-02-07: 2.6.0
    • DEV: Bump handlebars from 4.1.2 to 4.5.3 in /client-app (#102)
    • FEATURE: Linkify backtrace lines to github (#104)
    • UX: Keep the 50 most recent envs rather than the first 50 (#103). Also introduces new config options max_env_bytes and max_env_count_per_message.
    • FEATURE: Solve All button for messages grouped by pattern (#105)
    • FEATURE: Copy button for messages (#106)
    • DEV: Upgrade Ember to 3.15 and remove jQuery and lodash as dependencies (#107)
  • 2019-12-13: 2.5.1
    • DEV: Bump puma from 4.2.1 to 4.3.1 in /website (#100)
    • FIX: Don't include messages that were removed from groups due to max size limit
    • FIX: loadingEnv is an attribute of model
    • FIX: Prevent crashing when reporting a non-string message to Logster
    • UX: Group count attribute should be a long-running number of errors, not just the number of errors the group currently contains
  • 2019-12-12: 2.5.0
... (truncated)
Commits
GitHub
